- RISC OS on TV take 2
The Icon Bar: News and features: Native versus emulation in 2016 (Part 2)
Posted by Mark Stephens on 09:47, 16/12/2016 | , ,
In part 1 we outline our plans to pit a Titanium (running RISC OS 5) against VirtualRPC (running RISC OS 6) on the latest MacBookPro laptop. Here are the scores, Titanium first each time.
Titanium versus VirtualRPC
3762909 2115%, 524989 295%
27373 16896%, 9184 5669%
3253 1344%, 3067 1267%
42279 2113%, 26035 1301%
11622 745%, 5337 342%
Draw Fill - Plot filled shape
17204 1179%, 6021 412%
HD Read - Block load 8MB file
115924 3887%, 608316 20399%
84216 2769%, 530070 17430%
FS Read - Byte stream file in
2493 1204%, 2634 1272%
2553 1329%, 1170 609%
The 2.9gig Intel processor is not quick enough as an emulator to outperform a 1.5gig ARM chip on the Titanium but they said the new Macs have very fast SSD drives and that gives the Emulator an edge on block filesystem operations. You can compare these figures with those on Chris Hall's website (and try the tests yourself).
Does RISC OS performance on the MacBookPro vary if you run fullscreen or from battery?
A second question I posed last time was whether there would be any changes. Let us run it 3 times (in a window, in fullscreen mode and in fullscreen mode unplugged to see)...
525238 295%, 522668 293%, 522822 293%
9090 5611%, 9370 5783%, 9160 5654%
2947 1217%, 2913 1203%, 2899 1197%
20316 1015%, 20308 1015%, 24903 1245%
5396 345%, 5531 354%, 5457 349%
5994 410%, 6098 417%, 6045 414%
592095 19855%, 559651 18767%, 567762 19039%
481882 15846%, 527207 17336%, 522039 17166%
2593 1252%, 2657 1283%, 2653 1281%
1141 594%, 1168 608%, 1192 620%
So no notable differences between modes.
Conclusions
This article was partly intended as a bit of Christmas entertainment and the advantages will vary with your exact usage or requirements (the Mac laptop does use a lot more power for example, whereas the VirtualRPC solutions does provide a 'free' Apple Mac as part of the package). And you could always run Jeffrey Lee's excellent VNC server with the free VNC viewer built into the Mac as another combination.
Is this a fair test? Mazzeo's Law says that the answer to any big question is 'It all depends'. It will not give a true answer for every single use case but I would argue that it is a 'valid' test in that it makes a reasonable and repeatable comparison. The Acorn Emulator offers several different chip emulations (700,7500, StrongArm) and may well be better suited to colour modes with less than 16M colours. Stay tuned for Part 3 which will see if these result in a faster Acorn experience (or feel free to test yourself)...
My main conclusion is that both my systems offer a very viable RISC OS solution which allows me to use my favourite operating system at home (my Titanium) or on the move (my laptop).
And in the future...
I generally replace my work Mac every 2-3 years and the rumour mills like to speculate that Apple may move to ARM chips in the future. At the moment, Apple uses Intel chips, and you can currently use a program called BootCamp to intall Windows directly onto Apple Laptops. Commerial software from VMware, and Parallels, and the free VirtualBox allow you to create virtual machines using the Intel hardware. This is much faster as it does not have to emulate another chip. Running RISC OS on a high end ARM laptop with a solution like this would be very appealing....
  Bucksboy (18:09 18/12/2016)
  markee174 (17:32 19/12/2016)
    Bucksboy (18:22 19/12/2016)
George Greenfield Message #123969, posted by Bucksboy at 18:09, 18/12/2016
Thanks for that, Mark: any chance of some 'real world' comparisons?
Mark Stephens Message #123970, posted by markee174 at 17:32, 19/12/2016, in reply to message #123969
Does all the
work around here
Do you have any suggestions?
George Greenfield Message #123971, posted by Bucksboy at 18:22, 19/12/2016, in reply to message #123970
As you probably gathered from my comments to part one, my interest is in image manipulation, and I have found time to rotate a large (52 MB ) sprite or tiff to 45deg using Photodesk with a large* cache set - involving resizing as well as rotation - to be a good test of system speed. But Andrew Rawnsley mentioned Datapower file processing, and no doubt other commenters to pt. one will have their own favourites. The ideal test should call equally on processor, memory and disc access speed IMO.
*Around 120,000k for the file size mentioned.
