I figured it was about time for another oldschool review. This time I'll be talking about LASER, a game written by Mike Goldberg (and his cat) as part of his series of graphics programming articles in Acorn Computing magazine. The game was released on the subscription disc for the February 1994 issue of the magazine, along with a level editor so users could make their own puzzles.
The introduction
The game
If you haven't worked it out yet, LASER is a game about lasers, mirrors, radioactive sheep, and the soon-to-explode Sheepwell reactor. The action is fairly simple - You have to navigate the maze-like level and position the mirrors so that you can fire a laser into the heart of the reactor before the time limit is reached. The problem lies in that you can only fire the laser from "safe" zones (those without the radiation hazard symbol), and there are both destructible and indestructible walls in the way as barriers. And the occasional two-headed sheep.
The extras
As previously mentioned the game also comes with a level editor, which allows you to create your own levels (as well as take sneak peaks at the default ones). As with the game the editor is a simple single-tasking affair, using the keyboard to create and edit levels. You also get a few "cheat sheets", showing solutions to the last 4 levels of the game.
The verdict
Oldschool Reviews - LASER |
Q (20:55 11/4/2007) Phlamethrower (21:03 11/4/2007) Phlamethrower (21:54 11/4/2007) Q (23:13 11/4/2007) Phlamethrower (23:53 11/4/2007)
John Cartmell |
Message #101268, posted by Q at 20:55, 11/4/2007 |
Apparently your copy of LASER is written entirely in BASIC. My copy includes 8 modules and won't run on modern machines. Where did you get your copy? |
Jeffrey Lee |
Message #101270, posted by Phlamethrower at 21:03, 11/4/2007, in reply to message #101268 |
 Hot Hot Hot Hot Hot Hot Hot Hot Hot Hot Hot Hot Hot stuff
My copy should be straight from the original 1994 subscription disc (or from the archives that came on an AU CD). I'll check when I get home. It does definitely use modules for the sound effects, but if what you say is true (how modern is "modern"? ) then it's possible I tweaked it a bit to get it to run. |
Jeffrey Lee |
Message #101271, posted by Phlamethrower at 21:54, 11/4/2007, in reply to message #101270 |
If you comment out everything in the !Run file from 'RMEnsure MemAlloc' to 'ScreenSize 160' then it'll run on an Iyonix, too (Although there'll be no sound, and it'll need a speed fix if you want it to actually be playable) |
John Cartmell |
Message #101275, posted by Q at 23:13, 11/4/2007, in reply to message #101271 |
If you let me see just what changes you have made to the BASIC file I'll see if I can make the modified game an official release. And the same for any of the AU, AC, AW cover games and apps that can be made to work on 32-bit machines. |
Jeffrey Lee |
Message #101278, posted by Phlamethrower at 23:53, 11/4/2007, in reply to message #101275 |
130 SYS &42 TO TEMP 2510 DEF PROCP : REPEAT : SYS &42 TO TEMP2 : UNTIL TEMP2>TEMP+3 : TEMP=TEMP2
130 SYS &42 TO TEMP 590 PROCK : REPEAT : SYS &42 TO TEMP2 : UNTIL TEMP2>TEMP+3 : TEMP=TEMP2
Making the editor 32bit compatible is also possible - you just need to change the !Run file in the same way to stop it using MemAlloc, and edit line 50 of EDIT29 to match the above. |
