PhotoFiler is a long-standing RISC OS application. It is now freeware, and have just received its first update in 12 years thanks to Dave Thomas.
If you have not met PhotoFIler before, is one of those you install it, forget, it and wonder how you ever managed without it utilities. Once it is installed, you will be presented with thumbnail previews of any images. This is all transparent to you and instant.
PhotoFiler is very configurable and can interact with other image tools.
And PhotoFiler is very easily installed from PackMan (or you can download from GitHub).
PhotoFiler is well worth installing on your machines and running at startup. And it should definitely be on the RISC OS Direct build.
PhotoFiler on GitHub
PhotoFiler get first update in 12 years |
nunfetishist (08:13 7/9/2020) markee174 (17:18 7/9/2020) nunfetishist (11:07 8/9/2020) arawnsley (11:18 8/9/2020) Richard Hallas (12:50 18/9/2020) markee174 (21:29 18/9/2020)
Rob Kendrick |
Message #124939, posted by nunfetishist at 08:13, 7/9/2020 |
What is your process for getting these screen shots? They all seem to be scaled down, then scaled up to larger than original, and then with some subtle corruption thrown in in the form of thin lines where there shouldn't be anyway. |
Mark Stephens |
Message #124940, posted by markee174 at 17:18, 7/9/2020, in reply to message #124939 |
Does all the work around here
I usually take them on VNC on my Mac screen and then downscale in Preview. Do you have a better recommendation? |
Rob Kendrick |
Message #124941, posted by nunfetishist at 11:07, 8/9/2020, in reply to message #124940 |
I usually take them on VNC on my Mac screen and then downscale in Preview. Do you have a better recommendation? !Paint? |
Andrew Rawnsley |
Message #124942, posted by arawnsley at 11:18, 8/9/2020, in reply to message #124940 |
I'd recommend !Paint or !Snapper (the latter is slightly more complex to set up initially, but offers more flexibility and can grab things Paint cannot.
To downscale or change format, use !ChangeFSI or "The product formally known as ImageMaster" (ie. DPscan). There are others too.
All should be either part of your disc image, or can be download from !Store or PackMan for free. |
Richard Hallas |
Message #124946, posted by Richard Hallas at 12:50, 18/9/2020, in reply to message #124942 |
This is excellent news; I used to really like PhotoFiler. I'm surprised there hasn't been more interest in this post yet, and that no-one appears to have noticed that the link to PhotoFiler on Github is broken. (It needs to be edited to remove the Icon Bar URL and space that's prepended to the correct address.) |
Mark Stephens |
Message #124947, posted by markee174 at 21:29, 18/9/2020, in reply to message #124946 |
Fixed now. Thanks for spotting |
